ROSEWILL ARMER RX100-PU3-25B USB 3.0, 2.5" SATA I - II, 9.5MM UP TO 1 TB EXTERNAL HDD ENCLOSURE WITH WHITE LED INDICATOR, 100 PERCENT SCREW LESS Rosewill RX100-PU3-25B - Armer External 2.5" Hard Drive Enclosure - 9.5 mm HDDs Up to 1 TB, USB 3.0, SATA I / II, White LED Indicator, 100% Screw-Less AC Adapter: Yes Material: Plastic Dimensions: 0.59" x 3.39" x 5.16" Specifications: Support 2.5" SATA I / II HDD Also used with SATAIII HDD USB 5V powered High Power White LED Maximum Capacity (per Bay): Up to 1TB Weight: 0.90 lb. Package Contents: 1. RX100-PU3-25B Unit 2. HDD holding pad 3. USB 3.0 micro B to A Cable
Price: 14.99
